Tempted
RCM is smarter than me....
Tempted's Avatar
10.24.2008, 06:57 PM
Your statements can be seen just as biased as mine. You are defending a truck harder than I am disagreeing with it. If you re-read my post, I said nothing new about the Revo. Obviously the handling ability, or lack there of, is going to be a downfall to a truck with such a high CG and large tires. An E-Maxx with spools, a 72/10 spur/pinion and the wide ratio option will essentially be this truck. If you do much research you will find that even the reinforced 3905 diffs often fail because of the plastic cup. I have personally had many fail on me. As for a 4 channel 2.4ghz Tx, where? I know there is a 2.4ghz 2 channel and a new TQ4. Even those look like old TQ radios of the past. While I have my opinion and you have yours, there is no need to point fingers and say I'm wrong when we don't know what right is. I was just pointing out why I think the truck will fail and why an E-Maxx can do the same thing for much less money.
The answer is no. And yes, mine is faster.
