Pdelcast
Pdelcast's Avatar
10.25.2008, 11:41 AM
Originally Posted by asheck View Post
Looks to me like the torque is left to right on the graph.Which means the more load they put it under the lower the efficiency went.Which is to be expected. Looks like it reached about 34 oz/in of torque,with no rpm fall off.But it was down to 50% efficiency.Now if we only had the same graph for every other motor we could interpret some results.
No, the efficiency is the red line -- so at 34oz/in of torque, it was still at 84% efficiency.
Green is RPM, so the RPM was down to around 32500RPM
The 50% efficiency point is at around 240oz/in. (if my memory is correct)
This graph is a little misleading because at the right most point the motor is only outputting 1.21 horsepower. But we use this type of graph to do comparison testing between motors to determine if the motor iron is saturating early. A nice flat graph from left to right is the goal.
Patrick del Castillo
President, Principle Engineer
