Steve Krug
Steve Krug's Avatar
10.25.2008, 04:40 PM
Originally Posted by pumpkinfish View Post
Steve,
What motor mount are you using? Any issues with the stock kit diff mount on the other side? I mean, how much did you have to shim either one. Also, how did you mount your battery tray? I should have my MBX6 tomorrow and I'm trying to figure out what else I need. My 777 conversion was easy because I used an RCPD kit.
I'm using the RCM Mugen motor mount.
I actually did not shim the diff at all. It seems like there is no slop at all. All you really need is the RCM motor mount, and a battery tray.
I'm using the RCM battery tray and put a few shims on the bottom of the tray before mounting them using 3 of the stock chassis holes. I just split the stock radio tray in half just for the steering servo also. - actually, everything has taken alot of abuse so far with no breakage.
Hope this helps, feel free to ask any more questions.
