10.25.2008, 06:48 PM
Yeah, just divide the output gear (usually larger) by the input gear (usually smaller) together. And then multiply those ratios together.
If there are 3 gears (like the idler gear setup in the emaxx tranny), just divide the output gear by the input gear. You could divide the idler by the input, and then the output by the idler, but the result is the same.
