10.26.2008, 01:35 PM
I use one on my 10s Revo and I am happy with the results, I am a basher running in wide open spaces with no brakes, the ESC does have a soft start feature which can be a PITA if you want to race. I am using a pistix adapter which is needed if you use a pistol Tx if you cant locate one you wont be able to use an aircraft ESC, an alternative would be a Castle HV Hydra boat ESC you don"t need the pistix with that ESC
