brushlessboy16
brushlessboy16's Avatar
10.26.2008, 09:33 PM
How do you like the outrunner? I have an 833kv motor that I plan to use in my axial based crawler on 3s lipo. Only issue is that it has a 5mm shaft... I can fit a 9t pinion and 48t spur. Should give me comparable wheel speed to a 55t on 3s, and most likely alot more power...
belt drive instead of gears
