hemiblas
hemiblas's Avatar
10.26.2008, 10:12 PM
Thanks for the info guys. I looked at the shocks and I moved them out so they have more angle like Andrew32 said. I guess if you adjust them at the top you make them more verticle, at the bottom put them more at an angle. I didnt realize there were spacers in there but I could have just taken them out.
Turns out I had a busted lower A arm and I didnt even know it. The turnbuckles were keeping everything in place. Guess I should check the truck more often. I spend so much time researching power plants for these things I am a bit lost on the basics.
I did try it out with the new shock spacing and it runs much better. I can turn on a dime again at 3/4 top speed. I'm not going to try top speed until I replace the lower a arm. If its still a bit squirrley I will remove the spacers.
Thanks again.
