Shark413
Shark413's Avatar
10.26.2008, 11:31 PM
Here is the response I got from Steve Neu. I would recommend you contact Neumotors and ask them if you should send it in for a check-up. It will take awhile to have the motor checked out, but on the other hand you don't want the motor to come apart on you.
NeuMotors:
Hello,
It might be a good idea to send it in for a check-up. .05 is a little too much.
Steve Neusneu@neutronics.com
On Jul 17, 2008, at 2:19 PM, wrote:
Hi, I purchased a Neu 1515/1Y/F motor back in march 2008. Recently while cleaning/checking the motor I noticed some play in the front bearing. I tried to measure it with a dial indicator and I think it was about .05" worth of play.
Thanks
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
