Pdelcast
Pdelcast's Avatar
10.27.2008, 05:26 PM
Originally Posted by SpEEdyBL View Post
2. The equation for % efficiency of a motor is (VI - rI^2 - I0)/(VI) where V= volts, I = amps, r=resistance and I0 = amps at no load. So if you plot the graph as % efficiency vs. amps, you will see that if you use a higher voltage constant, you will get a higher max efficiency. But keep in mind this is only a theoretical equation and at some voltage, the efficiency starts to get worse. This voltage where peak efficiency is the highest is known as the sweet spot of the motor.
That equation only models electrical losses -- not magnetic losses (magnetic losses are lumped in with the IO constant...) Keep in mind that magnetic losses are non-linear (especially at high power.) Also, the IO constant needs to be measured at the same RPM as the output -- because other losses (like windage) are also non-constant (windage losses are RPM cubed...)
Patrick del Castillo
President, Principle Engineer
