stum
10.27.2008, 09:28 PM
The LPR's are very light weight, have very little roll (tiny sidewalls), don't balloon much and seem to be the top choices at just about every track under normal conditions. For truggy (arena) the holeshots most often, then the crimefighters, then the bowties in that order (even bowfighters at times mixmatch). Also common are the losi cubics (GRP I think). I will note typically using two different tires results in extra wear on the diff's so at least for me I blow them or have to rebuild much faster than running the same tires, just thought I'd thow that out there.
