Unsullied_Spy
Unsullied_Spy's Avatar
10.27.2008, 11:30 PM
Gear down is not the problem, the main problem will be the hub, knuckle and bearing tohandle this side load cause by the largest tires.
Is it that big of a deal on the CRT? I run them on a Traxxas Rustler and it seems to be holding up to them pretty well. It would be nice if Mike would make a kit that uses 8mm axles and an aluminum knuckle with big bearings and came with 17mm hexes--that would be a popular kit I'm betting.
