SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
10.28.2008, 09:17 PM
That equation only models electrical losses -- not magnetic losses (magnetic losses are lumped in with the IO constant...) Keep in mind that magnetic losses are non-linear (especially at high power.) Also, the IO constant needs to be measured at the same RPM as the output -- because other losses (like windage) are also non-constant (windage losses are RPM cubed...)
Thanks Patrick. Whoops, forgot to multiply I0 by V, but oh well, its only a theoretical equation that will result in a graph similar to the one posted. I knew there were other variables of some sort. Otherwise it makes feigaos seem really efficient!
Area 52 Ranch Raceway
T.R.C.R.
