Hardstyle
Hardstyle's Avatar
10.29.2008, 09:59 AM
I run a 1900kv motor with 6s2p of A123 cells- mucho powerful setup. Bearing in mind Castle say that you can use 6s lipo with the 2200kv motor, 6s of A123 is equal to 5s lipo, so its just about perfect (if you gear down a touch)
2200 x 19.8 is over 40k. That is quite alot. But have to think about it, im not in hurry, they are releasing the combo sometime next month right? Running 2200kv feigao/bk etc. with 6s2p a123, not a chance
Instead of the drill bit, I enlarged the hole and tapped mine to 3mm and used a yoke setscrew. It's stronger than that bit you used and guaranteed to stay in place too using blue loctite .
I forgot to take a picture of it but here's the same concept on my tmaxx/revo tranny.
Thanks, have to keep that in mind, if mine doesn't hold up
