coreyfro
10.29.2008, 02:34 PM
Awesome info!
I figured this was a good way to go because this is how a lot of hybrids work, they use brushless motors as generators when the ICE is performing optimally. I don't imagine that this is something that would be the primary focus of CC since you aren't in the market of making hybrids, but I doubt the technology is that much different.
So, this set up is so easy. It's all very trivially simple.
For cyclists, there are "Flip-Flop" hubs that have a fixed gear on one side (like a track bike) and a coaster gear on the other (like a BMX bike.) Off of the fixed gear, I'd attach the motor so that, so long as the vehicle is moving, the shaft of the motor is moving. If the motor is under power, the vehicle goes. When the motor isn't under power, it spins idle OR can generate power.
On the coaster side, the diesel engine. Simple engine, clutch set up allows the engine to idle at a stop, and the engine continues to idle until the wheel is spinning at the engine's optimal speed. Then engages.
When the engine is engaged, the motor idles or charges.
One speed, two power plants, existing bike parts, and a very simple bit of logic.
Now why would you say that? The efficiency is pretty good actually, it's just not optimized for generation.... but neither is a 3 phase bridge rectifier either. Above about 35% braking the motor starts dissipating a bit of power as the phase currents get really high -- and that causes a loss of efficiency.
The main difference is that a bridge won't ever BOOST the voltage for the battery -- if the battery voltage is lower than the motor EMF voltage, the bridge won't do a thing. An active boost brake (like on the Monster) will boost the voltage higher to charge the battery.
Patrick
