Originally Posted by megadork
I bought the tekno conversion kit for my revo. I'm finding that the clutch bell is rubbing on the side of the spur gear. Everything on that side of the engine mount needs to slide a bit closer towards the motor, but it doesn't seem like there's room. What am I doing wrong?
Do you have any pics we can check out? What motor are you running? The shaft on the motor may need to be cut or ground down a little bit depending on the motor you are running. Are you running any other mods on the tranny or chassis? Please provide as much info as possible and we'll be able to get you fixed up. Thanks.
