Oppressor
10.30.2008, 02:32 PM
What voltage do they run the motors at? 24v?
I believe that it's the official specs they have on that website, which mean 18v. It should run best at 5-6s.
Reading back i noted that i was wrong. I originally though that you wanted to run it on 4s. That said if i was you i would use the mamba max on 4s and run 14.4v dewalt instead of the 18v. They are 820 sized too i believe(only .2oz of difference so they should be).
They are cheaper to start with too.
http://www.robotcombat.com/products/BP396505-21.html
Of course ohm law is ohm law and they should be a bit less efficient but it shouldn't more than 1 or 2% of difference.
