Matthew_Armeni
Matthew_Armeni's Avatar
10.30.2008, 10:36 PM
Give the 50mm Medusas a try, great bang for your buck! 4800kv is a good 2s motor, 3300 good for 3s and most likely would gear up well to run 2s at reasonable speeds. Mine runs great, never been above 125* even with bigger truck tires
Also a great idea. I run a 50mm 2200kv in my Losi 8ight on 4s and it works great, so the CRT .5 should be easy on it.
  Send a message via AIM to Matthew_Armeni
