stum
10.31.2008, 12:47 AM
Originally Posted by shizzon View Post
I have been looking for a couple smaller mAH 5s lipos for running with a parallel connection in an E-revo with MMM and Teckno Neu 1515/1y. I am Looking for quality Enerland Based cells and I have been looking (especially at NeuEnergy's because there on sale right now) but i haven't found anything that looks large enough capacity.
Anyone with any links or ideas?
Thanks
The only way you are getting a 5s lipo config in an erevo is if you do 2s 5000 on one side and 3s 5000 on the other in series to equal 5s 5000. You get the longest run time from a 4s 8000mah setup vs any other voltage/size due to the battery compartment restraints.. you can get close with some 3s 5000's in series for 6s 5000 total, but the 4s 8k setup gets you a few extra minutes vs the 6s 5k setup. You would need to find some 3s 5400mah packs to sneak past the 4s 8k setup, and even then they have to fit in the battery trays.. 26mm tall I think max. I suggest going 4s 5k w/ the elite 35c cells, they rock and are pretty cheap. 8k packs that fit include the maxamps 20c 8k packs, the SPC 15c 8k packs and the true-rc 8k packs all these 8k packs perform on par w/ each other so get the cheapest.
