stum
10.31.2008, 01:03 AM
3s 4900xp fits no problem after you remove the spring on top of the battery box. 6s on that 1y is gonna be a bit extreme though. But if you do these cells should hold up just fine
Have you tried to fit a 30mm height pack? My MA 8k packs are 26mm and take up every last bit of the available height.. they even make the top bump up a little.... strange..
