stum
11.01.2008, 01:12 AM
Originally Posted by e-mike View Post
ive try this set-up but my lipo come realy wwwwwottt(160f)and it was a pair of maxamps 7.4 8000mah,,,,lowest timing.....this is why i switch to 6 cell...geared 14/68,,,im borderline(rpm) but my lipo are cold(97f)motor 150f after 30 minutes and esc 112f
The 8k packs don't typically get super hot until the last 1000mAH, if you are geared hot, I mean over 18/58 I wouldn't take the lipos to the LVC. I know what you mean about the temps though, I had one of my MA 8k packs poof a touch when running it hard to LVC also, but I was geared at 22 at the time. One pack was fine 130ish, the other was 150, mA replaced for free (warranty). I will say expecially with the 1.5d you need to be geared conservative to keep the amp draw down.. but high voltage is another good way to keep the amp draw lower as well :)
