Mozzy
Mozzy's Avatar
11.02.2008, 10:18 AM
That's definitely reverse & if you get hold of a "Forward only" conversion from Losi you'll be shedding weight from the truck. Mainly, that servo you asked about & alot of metal weight in your trans. I think it sheds about 300gm when you go forward only.
I'm sending 6 MM's back tomorrow. 3 failed after they refused to update the new software to fix the problems CC techs found, go figure. The other 3 basically failed in my truggy, all just went offline permanently.
Now I have none.
Steering servo & receiver works though.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
