Hardstyle
Hardstyle's Avatar
11.02.2008, 03:59 PM
Just quick Q. Can I get more speed with that mmm combo, without turning the electrics into Sauna? Now Briang's calculator shows 38mph with setup what im running..
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 16
Total Voltage: 19.8
Motor KV: 1853
Tire Diameter (inches): 5.7
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.0092
Spur/Pinion Ratio: 3.19 : 1
Total Ratio: 15.6242 : 1
Tire Circumference (inches): 17.91 inches (454.84 mm)
Total Motor Speed: 36689.4 RPM
Vehicle Speed: 39.82 mph (63.96 km/h)
Estimated Adjusted Speed: 38 mph (61 km/h) - 5% loss
Effective KV Value: 1853
KT constant: 0.73 oz-in/A
This what I had in mind.. 55mph, 50mph would satisfy as well
Additional Ratio: 1
Pinion Tooth Count: 18.6137
Battery Voltage: 19.8
Motor KV: 2200
Top Speed (MPH): 55
