Originally Posted by Jabe
i just fixed my suspension issue, just by changing to thicker oil and adding preload. now running losi front 50 rear 45, it might need thicker oil, so that 60wt is what you should try, and adding preload so that you get right ride height.
Cool, I was trying to decide if I should go with the 50 wt or the 60 wt, but now I will choose the 60. I was also looking for springs and found
these, and they might be the ticket. As much as I'd want to stay away from Integy, might as well give them a chance.
And you are right gtxracer, I know nothing about shocks and how they work, do you know of any good pages I could look at for information? Thank you.
