Thread: 8XL Gearing
hemiblas
hemiblas's Avatar
11.03.2008, 11:31 PM
If you want more speed just play around with the spur gear. They make them all the way down to 52 or something. At 21t you will notice incredible torque and you will probably not heat up as much as my 7xl. If you havent run this combo you will be thoroughly impressed. I got another stock emaxx just to compare and there is no comparison. With the titans you can have good low end, but dismal high end or good high end with bad low end. With the XL motors you get both.
My 7XL is still going strong. I have learned you cant run it in temps over 100 degrees or stuff starts to melt. During winter you should have no problems. My temps have dropped dramatically ever since temps got down to 75 during my runs.
