11.04.2008, 02:07 PM
Since the heat required to bend the lexan may be unhealthy for your lipos, I would cut a block of wood the same size as your pack and use that as the form. It should slide out and allow you to slide the pack in. And yeah, instead of glueing, you could just use heatshrink to keep the case together...
