hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
11.04.2008, 07:02 PM
I got the losi conversion on my 8ight and if you have the older V1 MMM with the battery wires and motor wires soldered to the board you will have zero clearance issues...however if you have the bullets soldered onto the board the MMM bullets will touch the body....but...you can solder the wires onto the bullets as some on this forum have already done b/c the extra male bullet on the other end of the wires raises the height of the bullet connector area and it hits the rear portion of the stock body/Jconcepts Illuzions body....Or you can just get an 8ight-e body and not have to worry about clearance issues....AND Driftbuggy means that the diff weights in the front/center/rear are 5,000/10,000/7,000...
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
