Thread: rc8t
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.06.2008, 11:17 AM
Originally Posted by Electric Dave View Post
Just playing a little bit of devils advocate here but why make your own chassis? Why not just use the OEM chassis and add components to it? I've seen that Tekno is doing the same thing (coming out with their own chassis) and I've been a little confused as to why...
I will say, that I've never replaced the chassis in my (old, 3 seasons) E-Truggy so I don't think it much matters either way.
Jhautz answered this for the most part, but I will throw in my 2 cents worth:
Some trucks simply don't balance well with the stock chassis conversions. The RC8 and a few others have the center diff pretty close to the center, so it has a tendency to be heavy on the battery side(unless a small pack is used). The Losi is well laid out for a conversion, as is the 808 buggy, while others(RC8, Tamiya since you mentioned it) can benefit from relocating some components.
While Tamiya's marketing regarding the straight drive train has validity(less wear and slightly less friction), it comes down to a matter of priority I suppose. You could drive a truck with a "straight drive train" that is off balance, but seldom wears out a drive pin, or you could drive a perfectly balanced truck that handles better and transitions better in turns, but requires drive shaft maintenence occasionally. The friction equation is marginal. I know my preference. Tamiya went "straight", but most others have gone "balanced".
The full chassis conversion also makes layout neater and cleaner(potentially of course) and has no extra holes to collect dirt or snag rx leads. Most "stock chassis" conversions are somewhat of a compromise - nitro layout works, but an electric specific layout has its advantages. We still offer(and always will) the individual parts for those looking to save some $ and use the stock chassis - if someone wants the most ideal, balanced platform, I would suggest the full chassis kit. :)
