11.06.2008, 11:05 PM
Originally Posted by JaySki View Post
Yes, I do have one.. in fact 4 of them. The only one I have opened was the one that I received the updated Case for after they sent the updated V3 to me. The other 3, no, I have not opened. I have no reason to... as.. they are under warranty.. and if they fail.. I'll send it in to Castle for Warranty Repair.
If you lack the desire to have a good look at what you are running, and attempt to understand it better that is fine with me. I see the fault in everything and do what I can to improve on it. That is why I posted pics and shared my insight.
Hobby Rule #1.... It isn't cheap. If you can't afford it.. as expendable money.. might want to rethink your hobby.
Hobby Rule #2... They break. And if you are racing, you better expect to have spares, especially the vulnerable stuff.. In this case, ESC, Servos, Push rods, Pinions, Spurs, drive shafts, etc... Unless you are OK with it breaking at a race and calling it a day. And that would apply to nearly anything you are DEPENDING on to stay working.
Having an esc fail is almost a given. I would rather make sure that it will be failing due to component issues than due to poor wire routing.
If you want to buy a dozen MMMs and have 5 spares go for it. I am sure that CC loves you for that!! I have tons of equipment, and never go without a running r/c. I don't race, or really bash that much. I build stuff. And I mod almost everything. Not everyone is content to run stuff stock out of the box, maybe you are. Either way is fine by me.
That's just Murphy's law. If it can break it will.. Therefor, have extras.
So, empathy.. Yea.. None. It's a hobby...
