Originally Posted by clowkoy
Can I use 4mm bullets on a Monster/Neu 1515 1.5 combo? Will it overheat the connectors? My MM/7xl on 4s run fine without heating issues. I just make sure the connectors are tight.
Thank you.
The real problem with running 4mm plugs is that there isn't much margin for error -- You probably won't have any issues, but do you really want to risk it?
I'd suggest using a 5.5mm connector as a minimum.
