George16
Supermaxx
George16's Avatar
11.08.2008, 02:44 AM
More update:
I installed the MMM today. I don't like the TeknoRC mounting position so I fabricated my own mount using 3mm aluminum.
Stock on right side, my creation on the left side:
After it was painted.
The holes line up with the rear shock mounts. I used 25mm spacers and 2 40mm caphead screws to mount it in place.
With industrial velcro:
I also lengthened the MMM switch wire:
My biggest concern. The positive bullet connector is too close or either touching the heat sink. I can't install a heat shrink around it.
The MMM temporarily mounted on the truck. The ESC sits lower now instead of being on top of the tranny.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
