11.12.2005, 11:42 PM
The difference in radio crystal compatibility comes down to positive or negative shift. There are other minor manufacturing differences, but it's the shift that matters most.
The Hitec HFS-03MM receiver I mentioned works with either shift; you just need to add compatible crystals for your radio.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
