11.08.2008, 11:05 PM
Originally Posted by Oppressor View Post
If it was me, i would stay away from any treatment involving heat. It might undo the heat treatment that the shaft probably received hence weakening it.
True, I ended up grinding the pinion on both sides and then split it with a pir of pliers. Easy when you know how...
