Originally Posted by JThiessen
Is that traxxas 2.4 radio even going to be available for purchase individually before chistmas?
I couldnt tell you anything about those servo's. Personally, I'd stick with the stock traxxas ones until you can afford to buy a single good one.
Also, If you are buying 4S batteries, you can ONLY run them in parrallel on the MMM - its only rated for 6S.
i hope the radio will release before otherwise i could try those glitch busters
i was thinking about staying stock but they cant be much worse than traxxas servos. better torque and speed. i want to save for a good single but i the 5955tg's are discontinued and replaced by the more expensive 7955tg and would need a programmer i think and an aluminum single arm. and as stated before im runnin them in parellel
