stum
11.09.2008, 01:39 PM
It is pretty easy to make any MMM it fit under any 8ight-b lid.. you simply trim the mounting plate that comes in the tekno kit in 1/2, make a couple new wire holes and then shave off the inside mounts for the transponder. Use some good mounting tape to adhear the transponder to the underside of the shortened mounting plate.
Zero height issues....
