MMM: No brushed motor limit?
MMM: No brushed motor limit? - 11.10.2008, 12:03 AM
For any CC engineer:
From the CC special projects page, the MMM is listed as having a 120A capability in brushless mode. Since the ESC is a basic H-bridge setup, that should mean in "brushed-with-reverse" mode, it should have the same 120A rating. And in "high-power brushed mode", it would be 360A. Is this correct?
Also, the specs say "no brushed limit". I assume you mean there is no turn limit for any single brushed motor. But, if several brushed motors were used in parallel, what is the limit? I would imagine that as long as the draw was under 120A, things should be fine?
Thanks!
