Originally Posted by BrianG
So are you saying the existing pulses would be further chopped? Isn't that the same as simply increasing the frequency of the pulses to get a finer resolution? Motor inductance would become an issue I would think...
In this case, increased pulse frequency would equate to higher motor speed since it is the primary motor pulse that would be modified.
This method would put a MUCH larger strain on the FETs since as the carrier pulse increases in frequency as motor speed increases, the carried pulses would need to increase in frequency as well to maintain the set duty cycle at a resolution suitable enough not to affect the efficiency of the system.
......Did I just say that??
