Smashwings
Smashwings's Avatar
11.10.2008, 05:19 PM
[QUOTE=mikey09120;231362]
Originally Posted by Carraig042 View Post
BTW. What gearing do you think I should use to start with in my E-Revo using 4s?
I was thinking 20tooth pinion and 62, 65, and 68 spur gears. Do you think that will be a good place to start with. I used the speed calculator, but I am new to the electric scene.
-Brett[/quotei plan on using 22t pinion and a 54t spur
Hi, I'm also waiting for the Monster Combo to be released, and would like to know which is the lower Spur gear you can use with this motor (suppose similar in diameter to Neu 1515 1Y), because I also have a 20 tooth pinion from my 700HO, and I want 40mph (track race).
So I can use my 20 T pinion with a 54 T Spur ? Or the motor would collide with transmission?
Differential Ratio: 2.8461538461538463
Transmission Ratio: 1.8333333333333333
Other Ratio: 1
Spur Tooth Count: 54
Pinion Tooth Count: 20
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0.1
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.7 : 1
Total Ratio: 14.08846 : 1
Tire Circumference (inches): 18.85 inches (478.78 mm)
Total Motor Speed: 32560 RPM
Vehicle Speed: 41.25 mph (66.27 km/h)
Estimated Adjusted Speed: 39 mph (63 km/h) - 5% loss
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Or I should buy a 22T pinion with 56 Spur?
Other Ratio: 1
Spur Tooth Count: 58
Pinion Tooth Count: 22
Total Voltage: 14.8
Motor KV: 2200
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.64 : 1
Total Ratio: 13.75641 : 1
Vehicle Speed: 42.25 mph (67.87 km/h)
Estimated Adjusted Speed: 40 mph (64 km/h) - 6% loss
