11.11.2008, 12:41 AM
Originally Posted by Tempted View Post
Actually I am very familiar with 20mph speeds in MTs and it is mind numbingly boring. Dogs can run at 45mph by the way. Sorry if yours is slow, guess you need a brushless motor. So how many watts does the 775 make? Why would it crawl better than a spooled Maxx truck? You can gear down on a Maxx truck and have all the torque you will ever want or need to crawl. I am willing to bet you right here and now that as soon as it sees a real MT sized brushless system the truck will fail imdiately. The drive angles are too steep, the gears are too low meaning too much torque to the gimmicky lockers and the ride height is too tall paired with the soft suspension meaning it will roll at any speeds above 15 or so MPH. So your telling me the E-Maxx has no steering servo problems? Your telling me it isn't a pain in the ass having to set them every time you take a big jump? And then adjusting the shifting and locker servos is gonna be great fun. So I'm foolishly asking you to answer questions you foolishly think you know. I'm stating facts about the machine, your saying that it looks cool on the video. On papaer this truck is terrible. Kids who like the looks and want lights will enjoy it.
Tempted- I was once young and headstrong myself. I would argue a point till no end. The fault with that logic is that you close your mind to the facts, and the argument becomes about winning, rather than coming to an amicable conclusion about the original question. If 20mph is too slow for you, I suggest not buying a traxxas summit. And, you got me, a highly trained racing greyhound can acheive 45mph, I too can google. I don't recall the exact numbers of the 775 motor, but traxxas states that the 775 has more torque than the two 550's, and they aren't in to false advertising, and you can see the same statement at kershaw designs about the very similar 820 sized motor conversion. There is a lot more to crawling than just torque. I explained in my earlier post that articulation plays a huge part in crawling, making the summit, with the phenomenal revo suspension, a much more capable crawler than any maxx truck. Apparently your reading comprehension leaves a little to be desired. About your bet: the gears have been proven. The shafts are even stronger than the well proven 3.3 shafts. Although race trucks don't sit at the same stance as a summit, that is simply ride height. While racing a truck will see full compression and full droop, going through the complete articulation of the suspension, so the steep angles you keep referring to have already been experienced and handled by traxxas slider shafts. And, back to the gearing, it's been proven. Of course a monster truck setup for crawling will roll if you try to carve a turn at 15-20 mph. No surprise there. Any experienced r/c'er knows to back off before turning to keep her on all fours. Stick around, I could teach you alot. I don't have any servo problems with my e-maxxes. If I did I would upgrade the part that is repeatedly failing, as simply repairing it and hoping for a different outcome is, by definition, insanity. Adjusting shifting servos is actually quite easy, not for you it seems, but it is a very simple procedure. Furthermore, the servos come preset, so why are you so worried about adjusting them? In fact, shifting servos are the easiest of servos to set as they only have two positions and don't need to be centered. You are not saying facts about the machine. You assume the drive line angle is too steep and will fail. You assume the gears will strip. All assumption and no fact. I don't say it looked cool on the video, I say that on the video it actually crawled over rocks that I don't think any of my maxxes could have. Thats fact. You say on paper the truck looks terrible. Maybe you should ask your mom for the big box of crayons with the sharpener on the back, so when you draw trucks on paper they won't look so terrible. If you want to talk crap about anything, upcoming or present, take it elsewhere. Nobody here likes negativity,and bashing on something just because you don't like it isn't tolerated, which is the real reason I wasted the time it took to write this response. If you have constructive criticism about something that may be sub-par, then by all means, share, but if all you want to do is say that sux, tell your mom as she tucks you in. If you don't have anything nice to say, don't say anything at all.
