J3110
11.11.2008, 06:53 AM
Now this is questioning. Aren't you an engineer? If you are, then you should know what happens when there is stress being added into a connection or joint, be it mechanical or electrical :.
That is exactly how I feel about the tight connections as well. Went through the exact same song and dance minus putting the shrink tubing on the connectors. Not too keen on the idea of mechanical stress on a solder joint, myself.
I almost feel like I'm being whiney or something after all the flak castle's taken for the failed units and I should just shut up and be happy it works.
At any rate, I will remain unhappy about that little detail and only hope that if it is going to result in a failure that it happens within the warrenty period.
Once the warranty is up, I'm crackin the case and "fixing" anything I think needs fixing.
I am sure that as far as castle is concerned, there's nothing wrong with these points.
