marzac2
marzac2's Avatar
11.12.2008, 03:22 AM
Damn, that looks great! Is that the new Tekno Neu motor with the built in mounting holes?
Yaa. It is the 3D - 1360kv. Gives the cleanest install and lowest CG by a small amount.
Originally Posted by lucias View Post
Is it a noticeable difference in run time when you use mechanical brakes?
Not really. Most of the real benefits are noticed right away and mostly they are performance related. Ability to coast through the air off jumps with ease. Slow rolling corners with confidence in the consistency of the "roll". And also the ability to adjust brake bias. The ability to have the rear end of the car brake before the front makes for consistent handling through corners and tighter turns.
I think the temps are noticeably lower though... so extra run time might also be noticed, though I haven't tested for it.
Thanks for the comments.
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
