11.12.2008, 11:15 AM
I have been testing these packs with various cells for about 10 months. They perform better under load than any other cells I have tested, so I decided to start selling them. I am working on labels for them now.
The 2500mah cells hold better than 3 volts per cell under 175 amp load(70c burst rate!) according to my Eagle tree tests! The Eagle tree is accurate to about this load, so I can't get a comparable test on the larger packs, but vs. a comparable FlightPower pack, you can feel the power difference (4s 5000mah felt like I almost added a cell!).
I have other packs, sizes as well - just not enough to list them yet. If anyone has a specific size they need, I should be able to get them - pretty much any size/discharge/capacity.
I will be testing a new 38c continuous 70c burst 2600mah pack soon as well, and should have 3s, 4s, 5s, 6s hard case packs in various capacities eventually as well. :)
