Thread: MMM alternative
11.14.2008, 10:42 AM
Originally Posted by florianz View Post
I give it a try, it says more or less:
"switched on the transmitter, connected a battery pack and got a greeting beep, so let's go. good acceleration, but it doesen't accelarate with full power from the beginning, but after a few meters, full power, which is good for the gears. very smooth brakes until the full stop. then throttle to neutral and backwards, no cogging or so.
during the drive some small problems, we will see which settings have to be changed. the temperature of the esc was 46 degrees, motor 56, at 17 degrees outdoor temperature."
sound pretty good to me, the breaks seem to work for cars,
florian
Originally Posted by Matthew_Armeni View Post
What about the throttle? Does it only offer a soft start or does it have full throttle right away? I run a clutch and mechanical brakes so reverse and motor brakes are not needed. I really want to run a real HV controller in my 8T but most are for planes and don't have the instant throttle I need to race.
Hope that helps.
