11.14.2008, 11:22 PM
Make sure the trimsetting on the transmitter is set to the center, then run the calibration setup. You know full throttle, turn on the MMM, beeps, full brake, beeps, neutral, beeps. Then you should be fine. But make sure all of the trim settings on the radio are at the center position while you do this.
to make it...
or break it...
Silent...But Deadly
