Originally Posted by Savage03
if you take out the one way can reverse be used from the esc? Now are you guys using the savage brakes or the esc brakes?
The only way reverse can be used via the esc/motor, is if you lock it up in a single gear... the same thing applies for the brakes on the esc/motor - must be locked in one gear to utilise the esc/motor in that way.
