bdebde
That's All Folks!
bdebde's Avatar
11.18.2008, 10:26 PM
If you dont change your gearing, you will see a lot more speed, but likely not much in run time. If you gear for the same speed, you will get more run time. of course it helps to have the motor rpm in a reasonable range too.
