bradleyk123
11.19.2008, 01:30 AM
the clutch has a set screw that holds it to the shaft. so all you need to do is unlock the clutch reassemble the gears use locktight on the set screw and then put your three screws back in to lock your clutch. I beleve this will fix your problem.
