balance tap issue
DickyT
balance tap issue - 11.21.2008, 09:02 AM
Last weekend I had a bad collision and the balance tap on my neu lipo was smashed. I ordered Hyperion taps to replace it so I do not have to always change adapters.
I tested the voltage on each balance lead and put them in the order, negative, 3.7v, 7.4v, 10.1v, 14.8v. When I test on volt meter they test fine, when I test my other packs wired with hyperion adapters they are layed out the same way, but the voltages are displayed as -3.7, -7.4, -10.1, and -14.8.
If I plug the neu pack into the balancer no cells are detected and the balancer get real hot.
I know I've done something wrong but can't figure out what. I'd like to get this pack working again before I go to the track sunday, otherwise i only have a heavy trc pack to run.
