bustitup
11.24.2008, 08:27 PM
You're right, the bottom plate should prevent that issue pretty much- I think Hoov discovered it just leaves a little light smoke damage around the edges of the plate; some unfortunate member of the idiot forum wasnt so lucky and suffered some damage to his lipos as his esc was stuck to the chassis directly...
Not to mention the hole it can burn through your lid if you don't get to it fast enough........mounting a esc stationary like that is kind of like not owning a fire extinguisher in your house because you don't think you will ever have a fire
