Team Associated RC8E
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Team Associated RC8E - 11.24.2008, 11:07 PM
Just came accross this on Neobuggy.net
The new Team Associated e-Conversion Kit has been designed for the RC8, RC8T, and SC8 to be easily and neatly converted from nitro to electric power. The e-Conversion is a well thought-out, practical design thathas been engineered to work as an integral part of the chassis. Enjoying the awesome power and convenience of LiPos in your SC8, RC8 or RC8T has never been easier!
• Rigid one-piece motor mount utilizes standard motor screw mounting pattern
• Large speed control mounting area raised off of chassis to allow for easy screw
mounting of common speed controllers
• Speed control mounting area includes convenient switch-mounting boss
• Utilizes 3 hook-and-loop straps to secure LiPo batteries into battery tray
• Molded Battery tray supports 7.4-14.8V battery packs with room for foam pads
• Accepts two ROAR-approved 1:10 scale size 7.4v LiPo battery packs (#703 Reedy
LiPo 5000 PRO (2), #704 Reedy LiPo 5000 w/connector (2), #705 Reedy LiPo 3200
w/connector (2), #709 Reedy LiPo 5000 35C (2))
• New sealed receiver box for proper electronics placement
• Receiver, Servo, and battery tray remove from car in one piece for easy maintenance
and cleaning
• Easy bolt-in chassis installation requires no modifications!
• Convenient wire routing keeps critical electronic wires out of drivetrain components
and simplifies disassembly
• Includes two pinion gears (15T, 16T) and two spur gears (46T & 50T)
• Comes with all needed hardware to mount components onto chassis
• Motor, ESC, and batteries are not included
• RC8 conversion requires RC8e body #89523
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
