Thread: R1Pro Cogging?
jhautz
jhautz's Avatar
11.25.2008, 04:09 PM
Check all of the connections and even resolder them all just to make sure you have good joints. Also do a good inspection of the Capacitors to make sure they werent damaged.
What settings are you using on the R1Pro? Set the start power to low and the timing all the way down to start with. Do you have the Hotwire for the R1Pro? If not, you should get it. It allows you to adjust some stuff that the standard button programing will not.
to make it...
or break it...
Silent...But Deadly
